Compression too high?
Old 06-26-2005, 12:31 PM
SilverStallion
SilverStallion's Avatar
Default Compression too high?
Could the stock 9:1 compression be too high to run 10 PSI of boost intercooled on 93 octane? Nothing seems to be solving my detonation problem...so I think lowering the compression is my last resort.
SilverStallion is offline
Old 06-26-2005, 12:43 PM
Quik
Quik's Avatar
Default RE: Compression too high?
9:1 is a fine CR. you soundnt have denotation but what is your A/F ratio? without knowing your A/F you really cant do any real configuring. chances are you are to lean. up the fuel pump, up hte injectors
Quik is offline
Old 06-26-2005, 01:06 PM
Grey Fox
Grey Fox's Avatar
If you have the fuel system to support it, and don't try to run too much timing, and run a boost retard, you should be OK with this setup.
Grey Fox is offline
Old 06-26-2005, 02:51 PM
SilverStallion
Well it was dyno tuned...guy said the A/F ratio should be perfect...and timing was 10 base, with 22 advance. 42# injectors with a 255 lph pump. Even when we retarded it to about 5 base there was still a slight ping under load. Noone seems to have an answer.
Old 06-26-2005, 03:03 PM
Quik
Quik's Avatar
lets see the dyno sheet. cause the guy may of not known what he was doing. i would like to see your A/F
and to sum it up no 10* isnt that much. buddy got a 9.2 CR 331 and runs 16* in his TT setup. putting down 560ish at the wheels
Quik is offline
Old 06-26-2005, 07:56 PM
Grey Fox
Grey Fox's Avatar
Run a colder spark plug perhaps?
Grey Fox is offline
CS2007
06-25-2019 09:45 PM
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Compression too high?
