Backfiring!
Backfiring!
hey guys so for the past couple weeks my car has been backfiring when i down shift. could this be an 02 sensor problem? what else could cause the car to go lean and backfire? thanks in advance
Not sure if this would be the same problem but after installing my O/R pipe the car would backfire when upshifting hard into 2nd. I did a decent tune up (cap, rotor, plugs, wires, coil) to try and fix a separate misfire issue and now the car doesn't backfire anymore when shifting. It was probably the cap/rotor and the plugs that helped the most because the cap had a ton of carbon buildup on it and the plugs had about .62 of gap when I took them out.
rpm match? u mean double clutch? thats what i usually do. i was teaching my buddy to drive a manual and i down shifted(not double clutch) and it backfired and thats the first time it ever did it.
