Backfiring!
Old 05-28-2009, 04:57 AM
95stang gt
95stang gt's Avatar
Question Backfiring!
hey guys so for the past couple weeks my car has been backfiring when i down shift. could this be an 02 sensor problem? what else could cause the car to go lean and backfire? thanks in advance
95stang gt is offline
Old 05-28-2009, 09:46 AM
golden_eye
golden_eye's Avatar
Not sure if this would be the same problem but after installing my O/R pipe the car would backfire when upshifting hard into 2nd. I did a decent tune up (cap, rotor, plugs, wires, coil) to try and fix a separate misfire issue and now the car doesn't backfire anymore when shifting. It was probably the cap/rotor and the plugs that helped the most because the cap had a ton of carbon buildup on it and the plugs had about .62 of gap when I took them out.
golden_eye is offline
Old 05-28-2009, 08:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
does it actually backfire or just popping/rumbling??
mjr46 is offline
Old 05-29-2009, 05:15 AM
95stang gt
95stang gt's Avatar
no it backfires. only when i down shift at high rpms though.
Old 05-29-2009, 09:28 AM
Canary94GT
Canary94GT's Avatar
Do you rpm-match? It's not so good (on your tranny) to straight downshift to a lower gear in high rpms.
Canary94GT is offline
Old 05-29-2009, 02:25 PM
95stang gt
95stang gt's Avatar
rpm match? u mean double clutch? thats what i usually do. i was teaching my buddy to drive a manual and i down shifted(not double clutch) and it backfired and thats the first time it ever did it.
Old 05-29-2009, 09:42 PM
mjr46
mjr46's Avatar
check the thermactor air system and make sure the check valve/ anti back fire gulp valve that screws on to the air tube that goes to the heads is not ruptured
mjr46 is offline
Sean
08-15-2004 03:50 PM
Disgustang
07-27-2004 09:43 AM
Obsol3te
07-26-2004 08:42 PM
spuckie
11-21-2003 05:51 PM
tchamber
11-09-2003 05:47 AM
Quick Reply: Backfiring!
