converting efi to carb
i have a GT40 P motor that i am coverting to a carb setup....i bought a 85 mustang distributor, msd 85-95 rotor cap and button, and i bought the adapter for the two.....am i going in the right direction?
you need a cap and rotor for a up to 85 and for the carbed version, most likely you got the cap and rotor for the efi 85 -95, and yes in 85 they had cfi/efi and there is a difference in the rotor of the efi vs the carb one........need a pic to verify what you got, also you'll need the duraspark ign box and coil.
EFI to carb
I would do an early 302 MSD dist, 6AL box, external Holley f/p, stay with the stock serp belt setup if you have it. You don't have to change the timing cover. If you don't have one get one from Jegs they are cheap.
dist
Much easier to do an MSD dist, 6AL and coil. Bolt on and go. Plug and play. No special wiring/rewiring.
Are you running a mechanical F/P or electric?
im running the summit brand of
Summit SUM-PUMPKIT7A for the fuel system with a grantelli pickup in the tank for the anodized fittings the guy thats helping me has a few mustangs with this setup with no issues
