Car Wont Start When Hot
I have a '93 5.0 lx with very low miles. The car starts cold and runs perfect. When I shut it off and try to restart it while its hot it either hesitates and starts or doesnt start at all. I can wait till it cools and restart it fine or I can jump it and it also runs fine.
It has a new mini high torque starter w heat wrap, a new 140amp alternator, and a new battery. Need some suggestions
Ignition module that's mounted on the distributor AKA TFI module. Known to have issues with overheating and causing your problems. Does the car ever shut down when running? Most likely this is the culprit.
it's a cranking insue, not a start/run issue......anyway to the Op...make sure all connections are tight and that the battery is good, how did you wire it???......you need to perform voltage drop tests on the wiring befoe and after connection transitions.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
