Starter relay?
Starter relay?
First off ive been having trouble starting my 94 GT it was hit and miss sometimes it would start and sometimes it wouldnt but only when cold so i checked a bunch of stuff and then i replaced the starter relay but my question is would a starter relay allow the car to crank but not fire any help would be appreciated i just want to make sure this was the problem
i already tried that my fuel pressure is 32 and i have spark but it is weak when cranking i think that is my problem just cant figure out why ive replaced the coil ,plugs,wires,and stator and cleaned all the sensors timings set at 12*it rruns fine when it starts and only gives me trouble on cold start
Suggestion.... try to spray a little carb cleaner in the TB before you do a cold start + you may want to run the DIY KOEO/KOER self tests. LUK
i rechecked my fuel pressure today along with the codes then i replaced my o2 sensors that was the only code so no more check engine light but i noticed that my fuel pressure wont hold it went up to 28 then dropped right down if i understand correctly it should hold for a little then i tryed cycling the key to try and build up pressure and it fired right up so im thinking its either the fuel pump or possibly a regulator any ideas
well when i try and start it on the first key turn it wont start then i tried cycling the key and it fired right up then i tied to start it again later on with one turn and no go then i cycled the key again and it started up so it has to be fuel related either the pump or the regulator just not sure on how to narrow it down the guy that owned it b4 me said he replaced the pump 10000 miles ago
Seanam
10-04-2015 10:15 AM
logan409
09-26-2015 07:43 PM
schecterplayer
09-23-2015 08:38 AM
