New Here Looking For Help (Compression)
Old 06-09-2009, 10:04 AM
ProTree750
ProTree750's Avatar
Default New Here Looking For Help (Compression)
I currently have a high compression setup 13:1 and wanting opinions on how to lower, its obvious the first thing would be to change pistons, or heads but before I start this project I want the best advice. I heard of going with thicker head gaskets can do the job but longetivity Im concerned about, whats your imput? Which way would you go. Budget is enough either way but trying to be conservative.
Thanks for the help in advance
ProTree750 is offline
Old 06-09-2009, 02:32 PM
Obsequious1
Obsequious1's Avatar
WELCOME TO MF'S
Check out the 5.0 section.
Obsequious1 is offline
Old 06-09-2009, 03:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
head gaskets won't be enough to lower it, you could open your chambers up some, but you'd need to measure the cc before and after and make it equal all across the board...do you have dome pistons or something???
mjr46 is offline
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
bconboy
09-21-2015 12:52 PM
uberstang1
09-20-2015 06:42 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Quick Reply: New Here Looking For Help (Compression)
