oil pan gasket walked out
hey i need to know if the chilton manual is right on how to remove the oil pan on my 94 gt. it says just lift the engine like 6 inches take the rack and pinion off and the pan should slide off. my question is how right is that? also i need to know the location of the pcv vale or where it goes into like the valve covers. i know it goes to the bottom of the intake manifoldbut where does it go to on the motor. thanx
RE: oil pan gasket walked out
that makes it sound a lot easier than it was for me. but generally yes.. unbolt the mounts lift it up about 6 inches and start taking off the parts in the way.. i dont remember what all had to come off but you will see when you are under there.
