331 CHP Dominator Long Block
Anyone have experiance with there long blocks or know anyone running one. I know guy selling a one. Says its set up for boost. Here is what he told me it has.
the motor is a 331 stroker built by chp it is a dominator motor,built for turbo, nitrous, or blower. Probe Industries SRS Forged Pistons (2618-T61) Probe Industries Forged 4340 Steel Crankshaft (Internally Balanced) Probe Industries Lightweight I-Beam Connecting Rods ,Probe Industries Tool Steel Wrist Pins, Fully Machined and Inspected DART Iron Eagle Block with Billet 4-Bolt Main Caps, Airflow Research Cylinder Heads 205,isky custom grind cam lift 672 intk 688 exht duration @.50 286 intk 294 exht, victor jr lower and upper intake aeromotive fuel rails, MSD distributer 6AL box and coil,Manley 4130 Steel Pushrods, Cloyes Original True Roller Timing Gear Set, Clevite Perfect Circle Rings Clevite 77 Main H-Bearings, Clevite 77 Rod H-Bearings, Balanced, Blueprinted Assembled to exacting tolerances and Inspected by CHP Master Engine Builders. you can go to http://www.coasthigh.com/product-p/11938-dm-f331-lb.htm |
sounds like it'll handle some power for sure. I myself haven't had any experiance with them. I heard that the chp brand cranks/rods are cheaper chinese versions of scat,eagle, etc. but if its all probe and if the price is good i'd say go for it.
