Ran lean, burnt gaskets, scorched pistons... ideas?
Thanks bud. Ran the codes and only got a 31 and 85 which is alright cause I have all egr/smog deleted. And since the computer doesn't give us any info I'll be going around and checking all voltages manually. Hopefully I can find something, if not I got a fp gauge I can hook up. I'll set the timing at 8* and try again. If it keeps persisting, well, I guess I'll look to get a chip burnt.. all I can do.
holy mackeral!!!! wtf happened there??^^^^^^better check all deck surfaces for trueness, make sure when reinstall occurs your torque wrench is calibrated and torque in proper sequence, or maybe you did all that?? never seen a gasket blow that bad on a N/A set up with standard compression.
Head bolts are stock... anyhow take a peak at new thread:
https://mustangforums.com/forum/5-0l...-help-bad.html
LivingInThePast
09-16-2015 12:20 PM
