Belt??
Belt??
I have a '94 GT and I just instaleld a new engine. When i installed the engine i deleted the smog pump and the ac compressor. A member here on the forum told me to use belt: 805K6 but twhen i install it it rubs between the idler pully and the water pump pully and i dont want to drive it like that.
Is there a way i can re-route the belt with a different size belt so im not chewing belts up?
Thank you for your help,
Rob
Rob
I got a shorter belt but the only way to route it is between the water pump pully and the idler pulley and there is barley enough room for them both and the slightly rub. I dont wanto chew up belts so i figured it would be a good time to take care of it.
Can I get a smaller idler pully and a smaller belt or can i delete the idler pully all together?
autoedit
09-27-2015 06:37 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
