car runs bad now
car runs bad now
I had an ignition issue before, turns out he tongue on the rotor finger wasnt touchign the cap. Then i tried playing with curb idle and ignition timing becuase it was bucking a bit at idle (sat aroudn 650), but before that it ran good, pulled hard. now the car bucks around 2000rpm when just driving, and when you hammer the throttle it backfires and has no get up.
engine is an 85 302HO carbed
stock distributor, didnt change tps sensor. It ran great 4 days ago, but then the distributor finger broke, so i put a new finger on, and then i played with ignition timing and the curb idle speed, and now its ****ty
stock distributor, didnt change sensor. It ran great 4 days ago, but then the distributor finger broke, so i put a new finger on, and then i played with ignition timing and the curb idle speed, and now its ****ty
did you really have to say that four times :-P
double check your wires it sounds like the wrong firing order i have dont that before. then after checking that check your timing set it to 10* and see how she runs
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
