info on tubular front end for a fox
is there any links or anything to get info on a tublar front end cuz im really thinking of putting one on on my other 87 gt , its wrecked in the front so that idea came across. thanks
RE: info on tubular front end for a fox
Well what kind of "info" are you looking for?
I picked up the QA1 Tubular K-member.
Was a good amount lighter than stock, but it lowered the front end a bit.
Not to mention the DS Front tire rubs a little too.
Going to need to figure out a way around that.
your lowered part comes from not having hte proper A arms and coil overs to adjust the height. also i think your rubbing is also an affect from the wrong A arms
didnt you also say it raised the motor up some?
Oh no sir, QA1 even states you can use all stock parts w/ their k-member.
So having the "wrong" a-arms is not an option.
Now if I had purchased the control arms... I would've had to get the coil over struts and get the springs for them. and get cc plates as well.
Costing well over 1000 buxx.
hey just got in . well i saw a article on MMFF mag and it showed a fox drag racer with the front end from the fire wall to the nose made all tubular. i know those things dont come in a damn kit but would llike to make one.
i just ordered my D&D K member along with my steeda adjustable plates. my price was 739.95.....no taxes no added fees.....got to love Laurel Mountain Mustang for all my hookups
what about the Granatelli tubular setup? if im not mistaken, you can get the kmember and a arms for under $500. i know you will need cc plates, but it still seems cheaper than the other things i read here. and i havent heard anything bad about Granatelli, so would that be a good suggestion?
