a/c problem in az :(
Old 06-18-2009, 04:11 AM
boonedj
boonedj's Avatar
Default a/c problem in az :(
ok i have a problem with my a/c. the problem is the compresser won't kick on unless you get under the hood and hot wire it what could cause this and how can i fix it? thanks for the help every one
boonedj is offline
Old 06-18-2009, 08:36 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Have you had your pressures checked or had the system refilled lately? If the pressure is wrong the high pressure or low pressure switch will kick in and not allow the compressor to engage.
projectresto83 is offline
Old 06-18-2009, 09:50 AM
mustangsneverdie
mustangsneverdie's Avatar
what are you hotwiring under the hood,the connector that goes to the switch on the dryer if that's what your hotwiring then that means your switch is bad
mustangsneverdie is offline
Old 06-18-2009, 12:10 PM
boonedj
boonedj's Avatar
im hot wireing the compressor and yes the levels are good
boonedj is offline
Old 06-18-2009, 12:33 PM
mustangsneverdie
ok well try the dryer connector and see if it will work then
vargas
06-17-2017 12:17 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
SteelerNation82
09-16-2015 07:11 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: a/c problem in az :(
