Clutch Issue?
Clutch Issue?
Here's the situation. Got in my car the other day and noticed the clutch peddle was quite stiff. As I pressed it, quite hard, I heard a loud Clank/Snap from under the dash and the peddle dropped to the floor. Immediately I thought it was the stock plastic quadrant and sure enough, the plastic hook was slipping off and causing the noise and peddle to fall to the floor.
I just got done replacing the quadrant with an aluminum Steeda one (god what a pain that was!). So here I am thinking everything is good again, I adjust the clutch cable (FW adjuster) so its nice and taught. I get back in the car, and the clutch pedal is still very hard to push and not smooth at all, kind of clumpy if that makes sense. Also, after pushing it in all the way, it doesn't spring back all the way.
I'm terrified that my clutch bit the dust even though I had it replaced it only a couple years ago. Any ideas of what could be going on?
I'm goin through the exact same thing u r. My pedal made the snap sound and I 2 replaced the quad with a steeda one but Im still waiting for fw adjuster (on backorder) I made my own adjuster though out of metal split washers and my clutch seems 2 be very stiff as well, at first I thought the clutch felt good then it got tight. I'm wondering if the clutch fork may be bent or not pivoting properly or if the cable is stretched I have a new cable but don't want to put it on till I get the adjuster. Itoo put my clutch inaprox 10,000 mi ago and highly don't believe the clutch went out. I know this really don't help ur situation butI'm fighting thesame battle as well.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
ccdguy
09-19-2015 05:20 PM
