question about 351 heads
Old 06-27-2009, 12:45 PM
jssblues
jssblues's Avatar
Question question about 351 heads
if i get a set of 351 windsor heads for my 306 to replace the junk e7's will i have any issues with my stock intake bolting to them?????
jssblues is offline
Old 06-27-2009, 12:56 PM
jssblues
jssblues's Avatar
these are 1978 stock windsor heads and i will be getting a great deal on them, they have to be better than the e7's right?????
jssblues is offline
Old 06-27-2009, 02:26 PM
FLcracker9
FLcracker9's Avatar
Unless they are D0OE heads, I'd pass and look for a set of GT40s if you can't afford aluminum. You won't gain anything because the late 70s heads suck too
FLcracker9 is offline
Old 06-27-2009, 03:02 PM
scottmach
scottmach's Avatar
Those 351 heads are probably worst. Small valves and huge combustion chambers. Junk.
scottmach is offline
Old 06-27-2009, 04:35 PM
87Stallion
87Stallion's Avatar
Yeah, I'd look for some GT40's. There not the best but you will notice a difference.
87Stallion is offline
Old 06-27-2009, 06:16 PM
aode08
aode08's Avatar
I would consider your stock heads, DOOE, GT-40, heads all garbage now.
You can get a set of LIGHTWEIGHT, ALUMINUM HEADS, that make better numbers, takes weight away, are easy to install and cost is cheap.
aode08 is offline
Old 06-27-2009, 08:33 PM
AdderMk2
Banned
AdderMk2's Avatar
dont run the D8's... they are definitly a worse head than what you have stock
AdderMk2 is offline
Old 06-27-2009, 08:43 PM
f1atlander
f1atlander's Avatar
not sure what your lookin to spend but i have a set of dooe's i'll let go for $100. ran good when pulled. here in GA
f1atlander is offline
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: question about 351 heads
