deleting smog and egr? and other questions
i got this 88 5.0 someone was building and they put a 93 motor in and converted to mass air. has a explorer intake on it. i have no clue where the vacuum lines go to off it. so need some help?
also not running ac, power steering , smog pump and no egr so what do i delete, plug and take out? there is like no vacuum lines hooked up anywheres. what do i do with the egr piece between the tb and intake etc?
exhaust is also l/t with h pipe with no cats
those vacum lines are gonna be your challenge. i deleted my a/c and smog pump. with the smog pump start at the pump and remove the lines back to the exhaust manifold and the other line should go to the exhaust. a/c about the same, start at ur compressor, disconect everything from the comp. and work back to remove the ac lines. i used an idler pulley in place of the smog pump and used a shorter belt. to delet the egr, i used a throttle body spacer that had the mount for the throttle cable. hope that helps
TfcCDR
09-14-2015 12:08 PM
