burning coolant! need some help.
my car is leaking coolant but i am not sure where exactly. I do however know its coming from behind the engine by the firewall and dripping onto the ground. The #8 plug is wet and i am guessing its leaking somewhere and being ignited in that cylinder. I have absolutely no clue as to where it might be leaking for it to be able to get into the cylinder. I hope someone here might be able to give me an idea where to look and what to do about it. thank you
Sounds like a head gasket leak. Usually when this happens the coolant will be gunky brown. A radiator shop can check this for you. The fix is replace the head gasket or you could try a product called Thermagasket. You flush the cooling system to get rid of all of the anti-freeze down to pure water. Next you add the two parts to water as directed then you drive the car for a period of time to keep it at operating temp. You leave the product in the system for two weeks, I think it is and then flush again. I have use it on a 5.0 and it worked very well for me. No guarantee, but might be worth a shot.
if the leak is external, check the hose that runs from the bottom/back of the lower intake and runs towards the passenger side into the firewall. i believe its the lower heater core hose. popped on all 3 of my fox's. its very hard to see where it connects to the intake, and not too much fun to replace, either. extendable mirrors and plenty of lighting will help here.
If it is leaking where the lower intake manifold meet's the BLOCK and not the HEAD's do not use a cork gasket. use a bead of silicone to seal it.
it could be at the head gasket, the head's could be warped from any number of things.
could also be from the intake manifold as stated.
good luck.
good luck.
if the leak is external as you state it's not being burnt by combustion but most likely it is getting on the headers which is what is burning, pressure test system and look for the leak with a led light and small mirror
