MM Roll bar?
I am also looking forward to hearing from you, I was interested in the same exact bar. Also, may i ask, what tach do you have in your car? i saw a vid and it had a digital RPM along with the mechanical needle.
Called the G-Tech Pro EGS
Nope. to add the 8-channel module it's 160 or something (that's coolant, trans temp, oil pressure and whatever else you feel like throwing on it, will read widebands in stock trim) I think it was... 350 or something like that, with the 4-stage shift light
Aha thank you. That's what about 25 grand.. maybe a bit more... will get you if you put it into a fox :\
Got the Roll Bar today after a hellish dealing with customs and brokers. First off I didn't know I needed to hire my own broker, so I got the call asking who my broker was, so I found a broker and hired them. Then the broker wouldn't take a MC or Visa and wanted a wire transfer, try and find a place to do that in Canada, eventually convinced them to take a money order. So all's good finally. NOT. Get a call from a DIFFERENT brokerage company saying they have my package, explained to them they aren't my broker and have it set-up with another broker, so then I call the shipping company and start screaming. Next day I got my shipment free of charge. So all worked out
ANYWAYS.
Played with it for about 2.5 hours and got it half way done roughly, all fell right into place and fit excellent. Only extremely minor thing I had to do was drill a rivet from a brake line underneath the car as the back-up plate wants to go there. Not a big deal. I see the floor's going to get crushed... A LOT when I tighten these bolts down, but what can you do? You're bolting a mostly flat, they did put a bend in it to help some, piece of steel to the floor boards which have creases everywhere. The wheel well back-up plates were the ones I was worried about most, as it is quite the bend they have in those plates, but, low and behold, it fit PERFECT. All in all, extremely happy with this kit. I will update as I go, I hope to have it done by Monday. Total installation time, minus welding and painting, should be roughly 5-6 hours. Here's some snaps for the curious, it's all just mocked up right now, haven't tightened any bolts yet to suck the floor up to the plates.
Oh, one thing, I do have one complaint. Whoever they are paying to pack the roll-bar, is getting paid waaaay too much. It took me a half hour to get the thing out of all the packing. Seriously, it's a roll-bar, don't worry about it getting dinged, worry about whatever is next to it.
This is the packing I had to deal with
Setup in the car
Main-hoop to floor (drivers)
Drivers swing out bar, hits the armrest, just going to move it in about 1/2" at the base plate then heat the armrest with a heat going and slam the door when I get it all in.
Pass. Rear brace sitting on wheel well.
Brake lines I had to drill out under pass side main hoop as back-up plate wanted to go where brake lines were, I'll just use a self tapping screw and screw it back onto the back-up plate.
Drivers main-hoop back-up plate
Duct taped back-up plate in drivers quarter (had no-one around to hold it in place while I marked the holes to drill, so I improvised)
Holes marked
Drilled 2 holes only, that way I had some manueverability after I set it in place for the other 2 holes
Bolted in with 2 bolts
Now all 4
Top side
I improvised here to as I didn't want to score up my freshly restored quarters, so I used some masking tape and marked where I have to drill it on that, now just drill that hole, no other scratching from my trying to mark it. (this is where the bar will go through on the passenger side [remember, mine has the new style quarters installed, if you have the older ones, like my car originally came with, you don't have that speaker, and will have to slice your panel])
ANYWAYS.
Setup in the car
Holes marked
Now all 4
Top side
I'll have some fresh pics tomorrow after everything fits 100%, then I just have to drill my quarter trim panels, take it out and weld and paint it, then bolt it back in. Hole ordeal took me about 5 hours. All went very smooth until the swing-out bars.
