what numbers should be on gears if i got 3.55 or 3.73?
07-16-2009, 06:21 PM
i got a new diff to put in and the guy said it had aftermarket gears, im gonna pull the cover off what numbers should be on gears if i got 3.55 or 3.73?
07-16-2009, 06:50 PM
Don't need to pull the cover to see what gears you have. Make a mark on the driveshaft and 1 of the rear tires. Then spin the tire and see how many turns the driveshaft makes to get one complete rotation of the tire. 3 and a 1/2 turns would mean 3.55's and 3 and 3/4 turns would mean 3.73s.
07-16-2009, 09:29 PM
diff is out of ca anyway. an cover is coming off but ill check that
07-16-2009, 10:06 PM
Oh well if the diff is out that's a different story, the gears will either be stamped with 3.55 or 3.73.
If you can't see the stamp, do what I suggested.
07-17-2009, 12:18 AM
my 3.27's are stamped on the pinion.but i dont think all gears are stamped though.could be wrong
07-17-2009, 07:04 AM
My ford racing gears are stamped on the ring gear, easy to see.
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
