High rpm missing
Old 07-08-2005, 09:53 PM
gwwjr96
gwwjr96's Avatar
Default RE: High rpm missing
ORIGINAL: 95_302_StangMan
someone is trying to wreck their engine.
well i dont see where he said he reved it that high while he wasnt in gear... but i have the same problem except its missing through the whole rpm range
gwwjr96 is offline
Old 07-09-2005, 01:10 AM
black89gt
black89gt's Avatar
i have a similar problem and once it hits around 4500, the rpm gauge just starts jumping like a rev limiter an d can never get it to shfit above 5000k either. i ahve an automatic by the way.
black89gt is offline
Old 07-10-2005, 10:21 PM
FoxGT
FoxGT's Avatar
I didn't take it that high, he did. I was just watching. & it has a rev limiter. The highest point it will reach is 7k after it first bounces it stays at 6300-6700rpm.
His wires are touching his headers & they are a little burnt. We can't do anything though at the moment. We took his transmission out.(we're swapping cases, his is damaged) It's sitting in my work room as of right now awaiting a speedometer gear (his was broken in two). I'll put my wires on there for a run up the road to see if that's the problem. Then I'll look into the rest of the suggestions. His car is sitting in my yard on bricks atm. [8D] I'll let you all know.
Thanks for the info guys.
FoxGT is offline
Old 07-10-2005, 10:49 PM
grabbem88
grabbem88's Avatar
change out coils..........my pos mallery did that in every gear at 4000-4500rpm,but in nuetral it revved fine(cause of lack of load on the motor).....tell him to try that first $20 at autozone..........
just to make this noted about revving at 7k..........BULL! your factory tach
is old and way out of calibration hell mine was 300rpm off when i put my new one in............didn't see about those plug wires...
you came over and didn't take my old ford plugs.....[&:]
grabbem88 is offline
CS2007
06-25-2019 09:45 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: High rpm missing
