Blower in a Fox...
Blower in a Fox...
I was just thinking yesterday, Ive never seen a blower like the ones in the newer mustangs, or cobras. Is it possible? I just ask because I think it would be a neat setup if I tryed it instead of going with the Vortecs and powerdyne's might be a nice change of pace.
RE: Blower in a Fox...
Only requires the GT40 if you're going with the flowzilla
Otherwise I believe you can use the stocker.
Been considering this blower for some time.
Still is a tossup between this blower or a Turbo(or two)
If you click that link and read at the very bottom of the page, it shows an example of what the blower could produce on a 302 engine.
How well does the new Kenne Bell BLOWZILLA/FLOWZILLA work? Muscle Mustangs and Fast Fords Editor Richard Holdener recently tested the Kenne Bell BLOWZILLA/FLOWZILLA kit on his own engine with the Westech engine dyno. The little 302 had #185 AFR heads, Comp Cams #274 cam, 75mm throttle body, 77mm mass air, Kenne Bell Switch Chip and 42 lb injectors. The combination made an amazing 508HP at 9.2 psi and 484 at 7.5 psi with a pavement ripping flat torque curve (453-483 ft lbs). 483 ft lbs @ 4000 rpm. That's 500" engine torque numbers. The boost never varied or dropped off from 2500 up - and there was another 9 psi left in the supercharger.
Saying it made those numbers on the 302, with those heads.
Now I plan on running twice as much boost, and I've got a couple more cubes to work with here.
Not to mention the insane power curve, so i'd be happy with either one really.
I agree It looks like a real clean setup for your ride.... Let us know what SuperCharger you gonna put in.
Im guessing your 331 will be pulling close to 600HP with all your mods.
Dragonus18
09-09-2015 01:21 AM
