i want more power...whats next???
here is what i have on my car,,,,whats next
main engine mods are:
bbk cold air intake w/ k&n filter
holley system max intake
GT-40P heads with 1.94/1.54 upsize stainless valves, hi-lift springs, 3 angle valve grind
Ford MotorSport E cam
FMS double roller timing chain
FMS Cobra 1.73 ratio roller rockers
FMS chromoly pushrods
speed pro 9.0:1 forged pistons
melling hi volume oil pump
24 lb injectors
mass air/24lb and cold air tuned
msd dizzy
3.73 gears
FMS stainless shorty headers
BBK offroad H-pipe
Hooker Max-flows & dumps
all electronics, fuel delivery, and injectors are stock
24 lb injectors
msd dizzy
3.73 gears
BBK offroad H-pipe
i'd say upgrade those heads and get some 30 lb's in there. also are you going to be boosted? if so then i'd say get some internals, perhaps 347.
maybe some suspension work before you get any more serious about gettin power. Subframes and some upper/lower control arms are a must even if you are running lower hp amounts just because you don't want to tweak the frame any.
Skip the tune right now and throw on a Vortech supercharger for $1800 New(You can find used for cheaper too). Then go get a tune. You will need larger injectors: 30lb injectors with an FMU, or 42lb injectors with no FMU.
speaking of which how did those 42# injectors work out for ya NoGo???
