which tranny is this..
Old 07-25-2009, 05:57 PM
fordsitsup698
fordsitsup698's Avatar
Default which tranny is this..
I have a question if anyone could help? I bought a motor and tranny together with 60k miles on it that came out of a town car, not sure what year but it is a 5.0 motor. does anyone know which tranny this is (RF-E0AP-7A040-BD). It's an auto tranny probably either an aod or aode. the pan shape is almost rectangled with a triangle shaped area off of drivers rear side and a smaller bit off passenger rear if that makes sense???? i need to know so i can buy a stall conv. before i drop it in my project and to see if i need a shortened drive shaft..
fordsitsup698 is offline
Old 07-25-2009, 06:43 PM
AdderMk2
Banned
AdderMk2's Avatar
that part number is for the tailshaft housing, take pics of it and let us know how many bolts there are in the pan
AdderMk2 is offline
Old 07-25-2009, 08:56 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what year town car,?? also are there any elec connections on the tranny other than the PRNDL switch??
mjr46 is offline
Old 07-29-2009, 01:27 PM
fordsitsup698
im not at home right now, my brother actually looked it up for me, and tried to explain over the phone. he said that its not prndl and that it's p r n d 2 1 (2nd & 1st i would only assume) as for the electronics I would more than likely have to look at it. I've read the AOD has p r n d l and the AOD-E has first, second then drive. is this true? it is a 5.0 towncar tho not sure on the year, that's what's giving me trouble.
Old 07-29-2009, 08:12 PM
mjr46
mjr46's Avatar
lol....I can tell your new at this PRNDL is a generic term used in the industry for that switch irregardless od the gear shift numerical order/number
mjr46 is offline
Old 07-29-2009, 08:26 PM
fordsitsup698
hahah yeah im new with this, but its a 14 bolt pattern pan, my brother said there is a switch beside the shifter and one switch towards the back, maybe near the tailshaft (not sure)??? i haven't looked at it in a few months since i've been at the beach the whole time. the car was 4 cyl 5 speed, i was just looking into the auto tranny to see if it was worth the time or if i should just go ahead and buy a tremec, if its the AOD-E i may look into it, if its just the AOD I'll more than likely just buy a tremec
Old 07-29-2009, 08:28 PM
AdderMk2
Banned
AdderMk2's Avatar
you arent going to put an AOD-E into a 90 without a good amount of work
just scrap the idea and ditch the slushbox
AdderMk2 is offline
Old 07-30-2009, 10:21 AM
fordsitsup698
hahah alright thanks for the advice anyways. is it the AOD-E tranny tho?
Old 07-30-2009, 01:49 PM
fordsitsup698
and if it is an AOD-E (if you know by what i've told you) will the ecu that came with the motor/tranny work compatibly with the AOD transmission? I'm not good with what will work with what as far as the ECU..
Old 07-30-2009, 01:52 PM
fordsitsup698
hahah and as far as the 4 cyl 5 spd ECU could it work properly with the 5.0 and a tremec
Quick Reply: which tranny is this..
