Fox motor in a sn95
So the timing cover and everything infront of it... ie the water pump, and all the accessories.? So i'll need to use my alt. smog pump, and power steering? Will my brackets bolt up to that block?
Really all i'm gonna use from the 1990 is the up to the heads... I'm gonna put on my 95 intake mani, all front accessories, and bellhousing... So all should be good to go from there.... The only electrical parts are for the starter and ground, and the harness for the injectors and alternator....so everything should bolt up fine...
Well i just gotta go pick up the motor, and i'll let ya guys know how everything goes. I'm gonna check the part numbers to see if the water pump is the same or not.... I should put a new one on anyways since i'm gonna be right there....
I just gotta get over to my old motor and pull off the balancer and the timing cover, i broke a bolt on the timing cover so that might be a bia to get off... BUt i'll figure it out. Thanks for all the input..
you need to use YOUR STOCK:
timing cover
water pump
pullies
accesssory brackets
tensioner
accessories
distributor
valve covers
wiring harness
starter
intake (there are differences in sensor locations)
bellhousing/trans
exhaust (or stock replacement... dont use fox exhaust)
