Hot Stang
Hot Stang
When I start my 1991 LX I'm getting white smoke from around the dash speaker on the drivers side, no warning lights and the car still runs great with no other issues. The smoke last about 30 seconds and stops. I'm thinking it could be something with the power windows, but thats just a guess. Does anyone know if there is a relay or something in that area that could be shorting out? I've had it apart and did not see any burnt wiring. I have the battery disconnected to prevent a fire, but I'm afraid to drive it until I can track down and fix the problem. Anyone have any ideas what it could be?
its electical for sure. no mistaking that smell. I'm thinking its nothing to do with the engine due to the fact I'm having no other side effects. (car starts and runs great) Is there connections or relays for things like power windows in that area that maybe get connected to the main wiring harness?
There's lots of crap in the corner of the dash, couldn't even begin to suggest just one. First thing I would do is pull out the headlight switch though, as I've had a few of them burn up on me.
Lay underneath and turn the key on while you're underneath and see if you can see where it's originating
I have a degree in electronics and installed audio security for a long time so you are correct, there is no mistaking that smell.
the switches in fox's are known to get hot and melt. That would be where I would start. You can pull the fuse to the headlights and parking lights to cut power to it and see if it quits smoking.
The problem is solved! After pulling the guage cluster, and all the trim. I could not see anything obvious so I started the car and still nothing happened. I then started moving wires around and bingo....the wiring harness for the window regulator saftey relay arched and a puff of white smoke. The harness was wedged between the body and the a metal support bracket for the dash and I guess over time vibration rubbed a hole through the wiring.I pulled the harness and repaired the wiring and everything is OK now...
