front drag light wheels wont fit with new pads!
Old 07-29-2009, 09:14 PM
stang8993
stang8993's Avatar
Angry front drag light wheels wont fit with new pads!
my front drag light wheels wont fit if i put new pads on,and there only half worn so i might need new front wheels,so what would the back spacing be?there hitting the calipers if i put new pads on and the wheel wont turn any ideas
stang8993 is offline
Old 07-29-2009, 09:16 PM
AdderMk2
Banned
AdderMk2's Avatar
3-5mm spacer
AdderMk2 is offline
Old 07-29-2009, 09:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check to see if the clip that holds the outer pad in the front caliper id contacting the rim, if so for a temp fix I ground the tops flat until 1/4 spacers arived from maximum motorsports
mjr46 is offline
Old 07-29-2009, 10:15 PM
stang8993
stang8993's Avatar
ive tried 1/4 spacers and the lugs wont touch the studs so i dont know where too get lugs with a longer shank,the wheel is hitting the caliper with new pads on
Old 07-30-2009, 07:45 AM
AdderMk2
Banned
AdderMk2's Avatar
are these weld draglites? or summit knockoff's?
If they are welds, you should be using the 1.75" deep shank lugs.. andthey SHOULD be working for you.
Summit sells the ones you need
AdderMk2 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
Urambo Tauro
12-17-2016 03:30 PM
NorthAmericanTuning
11-09-2016 11:44 AM
JonnyBlazeGT
11-03-2015 01:10 AM
inyadreems
08-21-2015 09:10 AM
Quick Reply: front drag light wheels wont fit with new pads!
