2 quick questions if i may.
I have an after market quadrant and it has 3 hooks on it, which one would i use? Also the clutch cable is aftermarket.
SEcond i was going to check my timing i know how to do it, but i was curiuos on where do u take the reading from on my timing pointer i assume its stock has a circle part. is that where i should shine the timing light? any hlp would be appreciated thx .
I prefer to use the last (closest to the firewall) hook, because if you use the first or second, and your quadrant moves around on the pedal assembly... it will result in a broken cable
look closely at the top most part of the pointer, it should say TIME
thats where you read from
