can u run flat top pistons with trick flow twisted wedge heads?
just got new heads an wanna know if i will have enough piston to valve clearence with my set up if u have a set up like this please let me know thanks.
TFS TW heads provide more clearance over the stock inline valve design (stock/aftermarket) due to the valve's steeper angle when used with flattop pistons. Obviously, to a point.... knowing more details of your setup would help. LUK
Like mentioned above, the only way to be sure is to check PTV clearance. My 302 is a perfect example. I have a stock bottom end, with Twisted Wedge heads, and my cam has a gross valve lift of .569 (custom CI cam). I don't have any issues with PTV clearance. The valve timing events machined into the camshaft affect PTV clearance just as much as lift. That's why it's important to degree the cam per the manufacturer's instructions.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
2003 4.75l
14
08-29-2015 02:58 AM
