***HELP!!! problems with 302 oil shafts twisting!!!***
I have a 89 gt with a 302. small top end mods including windsor heads, fo-mo-sport x cam, diff intake and proform carb. nothing major. but for some reason ive went through 4 oil shafts. the first two had twisted and caused the oil pump to stop therefore losing oil pressure, after the 2 i went with an ARP oil shaft and a highvolume moroso oil pump... and still yet ive had 2 MORE to twist and stop the oil pump. i need help bad!!
HV pumps are fine, but not always needed(good for higher rpm applications with looser bearing clearances). Being high volume isn't what's causing the shafts to break though, especially ARP shafts. But yeah, if you've been reusing the same pump the problem is most likely something int he pump itself.
Edit: I was wondering perhaps if there might be a pickup issue also. Crap in the pan around a pickup that's too low...the pump is trying to pull against major resistance. Definitely find out what the problem is though.
^^^like I said get the hv pump out of there, there is a prob with it, if pick up were clogged you'd know it, it would show up on the gauge as low pressure as well as in sufficient volume, since the op didn't mention such we can only assume pressure was fine???
Something is coming apart in the engine and causing the pump to lock up.Put a new pump and pick up in it,Clean the pan out.Check the valve springs and the oil seals if you have P.C. teflon. Make sure the pump shaft can move about .040 up and down when the pump is installed.Pick up to close to the pan, only creates loss of oil pressure, will not cause it to break shaft.Measure the depth of the pan near where the pick up is, then measure from the pan rail on the block to pick up,there should be at least 3/8" clearance.I usally measure without gasket just for a little saftey margin.
ok thanks for the help, but yes ive changed the pump 3 times and everytime the shaft comes out its twisted like a drill bit. im gonna pull the pump apart and inspect for debris and def measure to see where it picks up. ill keep you posted but anyways thanks again for the help, ive got a motor to pull lol.
