headlight cleaning
08-12-2009, 01:34 AM
headlight cleaning
Whats the best and easiest way to give my worn out headlights a decent shine?
08-12-2009, 03:18 AM
The Rogue Mod
Replace them!
Meguire's makes a kit. Check it out
08-12-2009, 03:56 AM
Depends on how bad they are. Mine were not that bad, but even after cleaning them with the off the shelf stuff they still looked bad. Just find a new set.
08-12-2009, 06:58 AM
D.R. THE PATHETIC DORK
rubbing compound and a high speed buffer = done in 5 min and look new
08-12-2009, 09:38 AM
as they said there is a kit available in the detail section of most autoparts stores similar to the powerball that connects to your drill. A powerball is also supposed to do this.
When you are done be sure to put a good quality uv safe clearcoat on it and it will last much much longer.
08-12-2009, 11:55 AM
Actually my headlights are not that bad they are just over due of a shine! does anybody know the sanding procedure?
08-12-2009, 12:48 PM
I used 3000 grit sandpaper and wet sanded them them buffed them with mothers chrome polish and a powerball on my drill. You'll be surprised how nice they will stay.I used liquid glass afterwards to give them a little extra. I'm cheap so I try to fix everything before I spend money even though they are cheap nowadays.
08-12-2009, 07:23 PM
Use the 3M kit from autozone. Best kit Ive ever used. Even better than the Meguiars. The 3M kit is like 20 bucks i think.
08-12-2009, 11:03 PM
I did my moms mountaineer, sand paper+ water = wet sand, compound, and buff.
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-29-2015 03:31 PM
folivier
09-26-2015 02:28 PM
