brake issue....
brake issue....
when i hit the brakes really hard and fast nothing happens really....but if i keep holding it they start to grab and stop me. the front brakes were bleed but i didnt touch the rears because i didnt mess with them. any ideas?
you have to bleed all the brakes when you bleed...air can get into them and cause serious spongy condition. go back and re-bleed make sure who ever is pumping doesnt release the pedal till after you tighten the bleeder screw completely...have them pump it 5 or 6 times then hold it down and when done you open the screw again..do this till no bubbles come out only straight fluid...start with pass rear then drivers rear then pass front and then drivers front....try that see what happens. after that check your vacuum tree and lines going to the brake booster to make sure your not getting a vac leak
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
