question: i just removing smog and a/c - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 08-22-2009, 04:22 PM
RedStang92
Question question: i just removing smog and a/c
well i just got done removing the smog and a/c and plugged the 2 vacuum lines, and when i started my car the first time it stalled, but the second time it was fine.. it also seems to kinda idle a little lower, but once i drove it around the block and turned it off and tried to start it again, it started right up but had a little hesitation like if it were to stall and but it didn't.
any ideas?
RedStang92 is offline
Old 08-23-2009, 06:09 PM
RedStang92
any ideas?
after all day today of driving and doin running around it would stall on first start.
Old 08-23-2009, 06:11 PM
mattdel
mattdel's Avatar
plug the holes in the heads?
mattdel is offline
Old 08-23-2009, 06:14 PM
RedStang92
well their is like square blocks in the back of the head so instead i just cut the line on the passanger side and put a bolt in it to block it off, idk if u can understand what im sayin but i can post pic
Old 08-23-2009, 07:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
make sure you capped off any emissions vac lines
mjr46 is offline
Old 08-24-2009, 02:52 AM
chickenbutt
chickenbutt's Avatar
which color vacum lines are they just to make sure i done this corectly? They are color cordinated right?
chickenbutt is offline
Old 08-24-2009, 07:09 AM
Tony71502
Tony71502's Avatar
The EGR vacuum is fed off of the upper intake manifold. Cap the vacuum source on the upper intake and you will not have a leak.
The exhaust gas ports on the back of the heads need plugged. You said you plugged the tube instead of the heads, make sure that bolt is sealed and not leaking. Also, I hope you plugged the tube coming from the H-pipe that feeds exhaust gas to the cylinder heads.
Tony71502 is offline
jwog666
01-07-2018 07:16 AM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
Teddi
09-29-2015 12:24 PM
BOB ROME
09-28-2015 11:10 AM
Quick Reply: question: i just removing smog and a/c
Featured Sponsors
