Throttle Body
Old 07-09-2005, 05:07 PM
5Liter Import Eater
5Liter Import Eater's Avatar
Default Throttle Body
I bought and installed a new bbk 65mm t/b with spacer. i torqued the t/b to the specified torque but i noticed orange liquid comin out where the t/b and spacer meet, right where the seal is. so i tightened it more and still the same problem. i dont see it leaking but i wipe up the dried up liquid and i check it like a week later and its all there again. its all around the seal of the t/b and spacer. what should i do? torque it more? its already past what it said to torque it too but i can tighten it more its not all the way tight.
please reply!!!
5Liter Import Eater is offline
Old 07-09-2005, 07:02 PM
razarr69
razarr69's Avatar
Default RE: Throttle Body
did you replace the gasket when you put the new tb on? cause it seems like that jus cuz its leaking all the way around. and perhaps is your antifreeze orange becuase i think thats what would be leaking from there.
razarr69 is offline
Old 07-09-2005, 09:55 PM
stanglx2002
stanglx2002's Avatar
you need to put new gaskets on
stanglx2002 is offline
Old 07-09-2005, 10:34 PM
vfast
I ♥ Acer
vfast's Avatar
put new gaskets and and put a lil copper tube between the 2 hose to bypass the spacer as you don't need to heat up the incoming air in the summer
vfast is offline
Old 07-09-2005, 11:57 PM
5Liter Import Eater
The new t/b came with new gastkets that i used
Old 07-09-2005, 11:58 PM
stanglx2002
sounds like you didnt get a tight seal
Old 07-10-2005, 12:06 AM
5Liter Import Eater
i think i have to torque it a lot more than it says. i already torqued it way past what it said to but it still feels like it needs to be tighter so i think i should try that, i just wanted to know if i over torque it if that will hurt anything?
Old 07-10-2005, 12:21 AM
vfast
I ♥ Acer
vfast's Avatar
then put it off and look to see if the gasket has a cut then when you reinstall put a very light bead of rv sealant just a really lite skin on the gaskets
vfast is offline
Old 07-10-2005, 12:26 AM
stanglx2002
i use ultra black gasket maker and it will seal that up for you
Old 07-11-2005, 02:24 AM
5Liter Import Eater
thanks ill try it and hope it works
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
guitarman376
09-30-2015 05:54 PM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Throttle Body
