Leaking Doors on Sunroofed Hatch
Take off your sunroof. Carefully pour water from a bottle into the drain. Make sure the car is level and water is flowing into every drain hole (there is one on every corner of the sunroof housing). If you see water coming out in front of the rear wheels and behind the front wheels, on both sides of the car, you don't have any clogs. If any one of them is not dispensing water, use compressed air and blow the junk out of that hole.
Here's a link over to our weatherstrip section too,if you guys want to check on prices.
Ford Mustang Weatherstrip 1A Auto Parts
I had the same issue on my non sunroofed hatch so I bent my window frames to seal up.also one thing to look at too is your door hinges my hinge bushings are shot so I still get a water leak above my side view mirror.so I got to do that.another way to find a leak around the door is use a flashlight and were ever you see light is a leak point.
09-25-2015 06:58 PM
