Fuel Pump Wont cut off
Old 09-05-2009, 02:03 AM
yosfynest11190
yosfynest11190's Avatar
Default Fuel Pump Wont cut off
I always had a problem with my fuel pump always running after i shut the car off, But it would stop after 5 minutes or 10 minutes after. Starting yesterday it stays on and now im having a problem i think it killed my battery. My car wont start and i get no lights on the dash i switched the battery out even tho its only a month old it killed the other battery just from moving it. i must have a short in my alternator harness may be? the harness and the alternator was replaced a month ago also Any clues about the fuel pump still running? and a reason why my car wont start?
yosfynest11190 is offline
Old 09-05-2009, 08:23 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you don't have a short in the alt harness, the system is completely seperate, your fp relay may be snafu or the ecm is triggering the relay when it shouldn't, recharge your battery and replace fuel pump relay= cheap and quick harry homeowner attempt at fix.
mjr46 is offline
Old 09-05-2009, 10:27 AM
yosfynest11190
thanks i will try to change the relay again
Old 09-09-2009, 01:51 PM
yosfynest11190
bump change the relay got a new battery and fuel pump still wont cut off i have to unplug it so it wont kill the battery??
Old 09-09-2009, 03:33 PM
kyle06786
kyle06786's Avatar
ide call up doc brown and hit him up for a new flux capacitor and then wind your car up to 88 miles an hour!!!
kyle06786 is offline
Old 09-10-2009, 04:58 PM
yosfynest11190
thanks that was big help
Old 09-10-2009, 05:50 PM
mattdel
mattdel's Avatar
changing the correct relay? the fuel pump relay is under the drivers seat, possibly even under the carpet depending on which plant the car was made at.
mattdel is offline
Old 09-10-2009, 05:52 PM
yosfynest11190
my fuel relay is right next to my cold air intake thats the one i changed
Old 09-10-2009, 06:31 PM
mattdel
mattdel's Avatar
unless you rewired it with another 10 feet of wiring and moved it yourself, you're wrong.
mattdel is offline
Old 09-10-2009, 06:54 PM
yosfynest11190
oh ok so i will check that tomorrow i didnt do anything to the car since i brought it. Im now looking at selling it tho for a cleaner rust free body fox
Quick Reply: Fuel Pump Wont cut off
