aod leak
aod leak
does felpro make a pan gasket for an aod? if so, whats the part number? couldnt find it on summit. i just did a pan gasket swap on my aod because it was leaking and the new gasket sucks. its leaking oil so fast the tranny will be drained in the next couple days. i have no idea how the gasket could seal so poorly. it was some cheap no name brand thin rubber thing.
also, approx. how many quarts of oil come out when you drain the pan. i know a few quarts are held in the converter, filter, lines and cooler, but i need to know how many i should buy to refill. my last tranny fried and burned oil onto the dipstick, its unreadable now
and if felpro doesnt make one, what do you guys recommend? im almost ready to just make my own gasket from silicone couldnt be any worse then the crap pepboys game me
make sure the bolt holes aren't tapered up towards the sealing surface. this happens from over torquing. completely flat surface, completely clean surface. both the pan and trans mating surface should be shiny new before a gasket install.
(AutoZone) Fel Pro Part # TOS18657
http://www.autozone.com/autozone/cat...andName=Felpro
appreciate it!
wish i had a lift, would make this job less of a pain in the a$$. hard to jam my 260# body under a car thats only 12" off the ground
any idea on the number of quarts?
any silicone?
the 24 hour autozone has one in stock, going to get it right now
bradleyb
11-27-2015 07:50 PM
