Christmas came early......what size injectors?
Hey everybody. I just picked up a DSS 306 with trick flow heads (stage two porting). I will be running a edelbrock rpm intake 70 mm tb. I was wondering what size injectors should I go with, also what mass air? Thanks in advance.
RE: Christmas came early......what size injectors?
ORIGINAL: BADNOTCH
It is estimated at 360hp. So with my intake setup I am hoping for 320 to 330. I tried to download pics but it wouldnt let me change the file size.
is that to the wheels? if thats flywheel hp, i still say 24lb'ers are your best bet. 30 lb injectors can sometimes cause hardstarting and other drivabilty issues.
true, true, stangpower.
Everyone i know runs 30lbs with the h/c/i cars with no problems at all even my freind with a ported cobra,custom grind and p/p stock heads has no problems,and plus you have enough injector if you want to go farther with your setup.
Nope just alittle owner tuning,other than that stock computers and everything so that's why i say 30's,The only problem they do have is a little rich condition at idle but nothing major so soon i will invest in a set of them.
