Interesting problem....
Old 07-11-2005, 02:17 PM
stangedout916
stangedout916's Avatar
Default Interesting problem....
well first off let me tell you bout the ride. i have an 88 gt conv. it has bbk intake, h pipe with flows and thats all rite now. i just got it not too long ago but the mods are already startin. but first i have to fix some things to make it a lil more reliable. now onto the probs...
first of all, if the car has been sitting over nite it starts fine even in pretty cold, which it doesnt get that cold considering im in cali. but then if i drive it enough to get the engine warm (like 45-hour) and park it for like 30 min or more it wont start until it cools completely off like 2 or more hours. if i try to start it less than 30 min parked it starts sometimes even if its hot. so this confuses me cuz i dont kno if its an ign prob or a fuel prob. on to the next prob...
in first gear when i first start driving if i press the gas too much the car stalls for a few secs then starts and runs again on its own. it also does this everytime i make a rite turn basically no matter what. usually it stops doin it in first gear if the engines warm and every once in awhile on rights. but the wierd thing is it starts itself back up and runs. now i dont know if this is pre-detonation of what. im just gettin into mustangs again and know some stuff but now a ton.
any help on either of these probs would be much appreciated. thanks
chris
stangedout916 is offline
Old 07-11-2005, 03:47 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: Interesting problem....
first I would check to see if the car was fixed under a recall for the ignition, then look at the solinold and starter
vfast is offline
Old 07-11-2005, 04:42 PM
stangedout916
i dont think i can find that out. i think the starters fine cuz its cranks fine. i think its a fuel thing. could it be?
Old 07-11-2005, 04:44 PM
99saleen351r
99saleen351r's Avatar
Its the ignition it happens all the time to fox bodies its not the fuel pump
99saleen351r is offline
Old 07-11-2005, 06:04 PM
stangedout916
ok so if its the ign, what do i need to replace? the ignition itself, cuz i already replaced the dist. and rotor. do i need a new coil also? how bout plugs? thanks for the help.
chris
baddog671
07-26-2016 01:20 PM
BeatnikFink
10-01-2015 08:00 PM
mdg
10-01-2015 07:04 AM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Interesting problem....
