Msd Trouble
Well, for starters-
Is this a self-contained MSD distributor? Is the ignition module working? Are the spark plugs wires attached and in the correct order? Is the ignition timing correct (which includes base timing, and rotor orientation to the correct terminal)? Do you have 12v to the coil and is it attached to the distributor?
