installing a AC Delete Kit
RE: installing a AC Delete Kit
id sell it for 30 bucks plus shipping. so figure about 10 bucks in shipping if that
now i got the proper belt to go along with the kit and its a poly cog. costed me 30 bucks id let it go with the kit for 10.
belt probably has 1500 miles on it.
You have to move the tensioner over to the march bracket. and will now be going upwards onto the underside groove part of the belt instead of downwards on the smooth part,to do this you have to replace the pulley on the tensioner with a groove one(reverse thread if I remember right it's been 5 or 6 years now, however i have had no problems at all with this setup, I also have the smog pump bypassed.
Here are some pics to help you out
[IMG]local://upfiles/5730/CF3CB62441D34029B74B17B7F9AEEB46.jpg[/IMG]
[IMG]local://upfiles/5730/30E3CAB8ACDC45A284A1789FFC0BAD33.jpg[/IMG]
[IMG]local://upfiles/5730/FC31E925657F4447938F80A6111BE3C8.jpg[/IMG]
i have it installed as well as the tensioner. THANKS GUYS. I just moved the tensioner where the AC Delete Kit is and the tensioner is upside down like it said to be. Do i really need a pulley with ridges on it or could i just use the stock one. I was just thinking of using the stock one if it works. What size belt do i need now? I have everything now except for the A/C and the tensioner is moved to where the AC is now. THANKS
09-01-2015 08:16 PM
kawiguy827
09-01-2015 07:09 PM
