clutch problems
09-18-2009, 09:25 PM
clutch problems
aight i changed my pilot and throw out barings twice my car is still makin a noise that stops when i hit the clutch..i just bought a new clutch fork and pivot point but have not put it on if it makes the same noise once i do dose ANYONE know what it might be?? it sounds like a loose belt it kinda sounds like a sqeekin sound ANY SUGGESTIONS WILL HELP thanks
09-18-2009, 09:28 PM
The Rogue Mod
Maybe it something inside the tranny itself. What does the condition of the bearing retainer look like?
09-18-2009, 10:28 PM
Yeah if you still have the stock bearing retainer i would change it while your down there. Mine had a nice groove worn in it which i think was causeing my problems
09-20-2009, 06:15 PM
Take transmission out and take apart. Problem should be obvious. When you pushed clutch in the drive input stopped turning inside transmission. Noise gone. Look inside transmission.
09-21-2009, 04:17 PM
To be more specific check input bearing and bearing from mainshaft to input shaft.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
MasterLanMan
09-13-2015 08:21 PM
Brandonfilipponi@yahoo.com
09-12-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
