Rocker question
Rocker question
Well after 2 1/2 years I finally got to fire up my Mustang project 3 days ago. It isn't road ready yet(still have some miscellaneous odds and ends to tie up and it still has one more trip to my buddies body shop) but the engine fires right up no problem and runs like a champ. My question is about rocker noise. I can hear the rockers when the engine is running. It is not loud by any means but I was wondering if it was normal to hear them since they were aftermarket. They are Ford Racing pedestal mount rockers and I torqued them to spec. Any info is helpful. I'd like to thank mjr46 especially for his help with my project. thanks bro
No, I just sat each one down and torqued them. I did a little reading on another forum and learned that I need to make sure that each one is on the base circle of the cam so the rocker isn't in a bind. I plan on doing that tomorrow.
Crank the motor until you are sure the valves are fully closed, then torque. That's what I have been told to do and have done.
BTW the rocker can't be bound by the spring(under huge pressure) when the valve is closed.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
