302 rebuild
302 rebuild
Quick question- I found a 302 long block that ran good when it was pulled 15 years ago. It's been sitting in dry storage covered up...The spark plugs are still in, minus carb but that has been covered up with a rag stuffed down the intake. The engine itself has 70k miles. I'm planing a complete tare down and repacing the crank, rods and pistons and everything else including replacing the heads with alum.....and so on... If the engine has been in storage for that long will the block be anygood for machine work? Or has it been sitting just to long?
Thanks,
Richard
Thanks,
Richard
Richard; If that really a '68 302 you got hold thats an excellant find. Theres quite a bit more metal in it than the later stuff.
If you are lucky (50% of time) they'll sonic test thick enough to take .060 overbore.
Good block to use for a stroker motor........
Yup, got it home a few days ago...tore it apart. All looks good, standard bore with little wear on cylinder walls. The crankshaft has a little groving towards the front. Engine casting numbers are C80E-6015-A and the heads #'s are C80E 2V heads
Oh and I dont think it came from a Maverick! I'm thinking Fairlane? Not sure Ford made a 68 Maverick.
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
