Putting in a new clutch
I'm putting a new clutch in my 1995 gt Monday morning. Right now it seems hard to shift it all around. Its drivable but it just doesn't seem like it should be. The clutch that is in it now has 180,000 miles on it. I'm hoping that the clutch is not disengaging 100% so its making it a little difficult to shift. Is this possible and will a new clutch make this any better? I'm just hoping there is no tranny problems.
it might
if the clutch is engaging about 1 1/2" off the floor it is working properly though
did you adjust it at all ?? the stock adjustment is by lifting the pedal up hard... then push it in a couple times... then lift it again and just do the whole thing til it stops "ratcheting"
But yes, if you lift it up, you don't have to lift up hard, just lightly until it stops, will only move say about a half inch over its resting place, if it doesn't click, it's adjusted as far as the factory is concerned.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
