fuel pressure?
Old 09-29-2009, 04:16 PM
wterrell
wterrell's Avatar
Default fuel pressure?
at idle 30 psi. 40 when floored is that normal? no load on motor at 2000 rpm 28 psi.
wterrell is offline
Old 09-29-2009, 04:23 PM
mattdel
mattdel's Avatar
within spec for idle and WOT, but the 28 is a bit low. regulator might be on its way out.
mattdel is offline
Old 09-29-2009, 08:22 PM
nitrous_bob
nitrous_bob's Avatar
usually spikes to 42 on WOT, so yeah a bit low
what does it go to if you pull the vac line from the reg ? if it does NOT go to 42... i'd say reg or pump is going bad
nitrous_bob is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: fuel pressure?
