car leaking oil.
car leaking oil.
how do you check for that? i woke up this morning and found a puddle under my car and it's oil is there any way to check for that or do i have to take it to a shop to get it fixed?
EDIT : took a look at it found a tiny little whole in my oil pan any suggestions on how to get that fixed?
if you have tiny holes in your pan you need to replace it. more than likely oil is seeping out of the pan even where you cant see holes. bring it to a shop to get it done unless you are capable and willing to do it in your driveway.
U are going to have to put it in the air unbolt your k memeber, let it hang and take the pan off carfully, clean up the pan and weld the hole. i did it on my car. i had a hair line crack on the bottom of my moroso.... but it got the job done
good **** man thanks alot
91StangOwner
08-20-2015 11:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
