let's have a lil fun look inside
ok..lets put your mind in gear.....I challage you to due a mock engine build up..ie..let's see engine build up..must list every part you use with specs...NO POWER ADDERS all engine,then will run it threw the desk dyno....can be carb or FI..
ie heads with valve size and what kind as well as port size etc..
what headers etc
good luck
what headers etc
good luck
RE: let's have a lil fun look inside
just design and engine and list all of the specs on here. VFast will put the specs into desktop dyno. see who designs the engine that produces the most power. Whats so hard to understand?
ORIGINAL: bobby
