5.0 to 2.3?!
The AOD will not bolt up. You will need an A4LD if you want to stick with an auto. You can use the same rear but you will need a different driveshaft(I believe). turbo 2.3, harness(depends on mass air or map), reroute fuel lines. I'm sure I am missing something. Why would do that? That would be a lot of work with nothing to show for it.
the reason is to do something different
the stock a4ld won't hold up well to it. Some people have ran a c4 using an older pinto bellhousing. I ran a t5 for mine because it holds up to quite a bit if treated right. They use a vam instead of a maf. Not such a good thing, but it got the job done. Some people have switched over to using a maf. I personally went the standalone route & ditched the air meter all together for less inlet restrictions so mine is setup as speed density. You would need the pistons, computer, engine harness, & air meter from a 2.3t car. The rest of the parts can be had from a n/a 2.3, you'll need the fuel lines too (they come out on the drivers side instead of passenger like the v8). The weak link to the n/a engines is the pistons. Everything else will hold up to around 400hp, some have pushed it above (there's actually a guy on this forum running around 540whp with the stock bottom end). The stock n/a pistons will give out around 5psi. The 2.3t itself is pretty well bulletproof.
The big problem with the 4 cylinder is the head. A good aftermarket aluminum one will set you back $2000 which is pretty crazy. Boport is a pretty recognized company for porting the stockers (aswell as aftermarket ones) getting them in the 400+ hp range
http://www.stinger-performance.com/bolton.html This guy is running one.
I had the chance to buy an svo for $1000. The reason I turned it down is because of their value, I knew I was going to end up modifying the car, so I bought a notchback & put a 2.3t in it. After I got a 351w I ended up swapping the 2.3 into my ranger for a quick work truck. Personally I'd just buy a junk mustang with a blown engine or something for it. The low end power is nice to play around with sometimes.
