Decking a block question
well it all depends on if the piston was in the hole or if it was zero decked when it was
O-ringed you should have mocked up the engine with the pistons you were gone to use to see if had the room to take the O-ring grooves out. but if it does stick out you could get thicker gasket to make up some of the difference if you need to Cometic sell them them are not cheap but they are good.
09-08-2015 05:21 PM
